If the particular
inputs condition is true, a ‘gosub’ to the interrupt sub-procedure is executed
immediately. When the sub-procedure has been carried out, program execution
continues from the main program.
also see note 2 on the same page of the PICAXE manual about resumeing interrrupt capabilities:Notes:
1) Every program which uses the SETINT command must have a corresponding
interrupt: sub-procedure (terminated with a return command) at the bottom of the program.
2) When the interrupt occurs, the interrupt is permanently disabled. Therefore to re-enable the interrupt (if desired) a SETINT command must be used within
the interrupt: sub-procedure itself. The interrupt will not be enabled until the ‘return’ command is executed.
I love a manual that makes you learn things the old fashion way ... earn it!... does sort of state that ...
