Hello all,
Been happily experimenting away with my Picaxe for a little while now. Its a good bit of fun and so easy and 'accessible'.
However something seems to have changed in such a way that I can not seem to program my hardware anymore.
I'm getting an "Error - Hardware not found on COMx" error for the past couple of days.
Now I've read posts before about resetting the chip and testing the connection. However I've tried those kind of suggestions and find the problem doesn't appear to be in any of those areas.
In fact if I take the cable (axe027) and original rev-ed projectboard to my office, hook it up and start the software everyhting is just working fine.
I haven't changed anything to my PC hardware/configuration. Software wise I can't think of anything either. In fact I dont remember installing any new software or drivers at all so that shouldn't have affected the situation.
My home PC is running on windows 7 x64, the workstation at my office is still at Xp x32.
The only thing odd that I can recall when I trace back is the following.
My PC at home (notebook) has got 3 USB ports to which I can connect the AXE027 cable adapter.
Installing the driver using the driver executable doesn't work under Win7x64 however after unzipping and manually installing the driver through device manager worked just fine for me.
I do recall having issues in the past but then I'd connect to another USB port and all was well again.... for a little while.
Now it seems almost as if I've used all ports and things have quit working.
I tried uninstalling the drivers to start afresh but it didn't help.
Is there any known issues like this that i am not aware of or would anyone have a suggestion about what else I can try to get it going again ??
Thanks already,
Patrick
Thanks already,
Patrick
