donrecardo
Hi
I said a question maybe for Hippy as after doing a search in this forum for hall effect it pulled up a post answered by Hippy that I think answered what I want but I just wanted to confirm it
I need to count rotations of a wheel . I have an Allegro A1104 hall effect switch that has the hall effect sensor, schmitt trigger and NMOS output transistor. My plan was to mount a magnet on the rear face of the wheel and place the sensor near its path hopefully to count the pulses as the magnet passes the sensor.
I dont think I have used an NMOS transistor before but looking at the diagram , had it been a normal NPN transistor I would have said it was wired as an open collector .
So am I right in thinking , all I need to do to interface it is connect its vcc and gnd pins to my 5v and 0v . and connect the output to an input on the picaxe , but tie that point also to the 5v rail through a pull up resistor of say 4k7 ?
I then assume that I will get a constant high on the input pin until the magnet passes the sensor when the input will blip low ?
Lastly , and not connected with Picaxe. The wheel I need to mount the magnet on is made of mild steel so is ferrous, Will the magnet just make the steel wheel appear to the hall sensor as one large magnet , or will it still have a higher magnetism as the magnet nears the sensor.? Put another way. will it still work even though the magnet is mounted on a ferrous material
Cheers
Don
Cheers
Don
