Gentlemen:
It's has been a while, but in the mean time I have learned a bunch. I am at a loss right now though, and I have a question. I am working with a 18x Picaxe. I have successfully down loaded programs into it and I currently have it controlling transistors that turn 12v lights on and off. I am now trying to use the 1702 low drop out voltage regulator to power the picaxe off of a 12v battery. I have the data sheet in front of me and I have successfully hooked the regulator up. Using a multimeter I am getting 5 volts out of the voltage out line. I have the 5 volt line connected to 5 volt positive rail that the pic chip is connected to. The ground for the 12 v battery is connected to the negative rail that the pic chip also connects to. When I try and down load a program into this it doesn't work. I have checked the voltage on the rails going into the pic and I am getting 5 volts. Now for my question. It won't work as I have described it, but if I connect a 4.5 v battery to the same rails that the 12 v battery is connected to, the program down loads great. Before you ask, I don't have a schematic to down load. If you would suggest a program where I can draw one up, I would be happy to make one up and show you. When the two batterys are connected to the rails the voltage is the same. The only difference is that it won't down load unless the 3 double A batterys are connected. There is no voltage difference on the rails. Any help would be appreciated.
