Hi all. Since my last Halloween picaxe project turned into the Nightmare on Howe Place (but actually ran flawlessly on the Big Night), I thought I would get a jump on this year's project. It entails 3 witches having a "conversation", using an 18M2 and 3 Tenda mp3 boards. The witches will all chant together, then have the picaxe randomly select one of seven chants, of which they will each say a line. The 18M2 will use the RX line on the Tendas' to send commands and will monitor the "Busy" line on the Tendas' to signal when to move to the next section of code. Here is the preliminary code, it is incomplete (does not have the "random" section yet, nor all seven chants) and I have not downloaded it into an 18M2 yet. However, I have run syntax on it and am coming up with an error on the line "if Aggie_BZ = 1 then". I'm not sure why that is, as I have used almost an exact version of that line in another code and had no such error.
I am unsure of a couple of things, how to generate the random choosing of the verses ( I know how to generate random pause times, not sure how that would apply to whole sections of code) and where to insert it into the code. Any suggestions greatly appreciated.
'18M2 Picaxe control for multiple Tenda boards for Witch conversations
symbol Aggie = B.0 'Tenda 1 RX
symbol Gertie = B.2 'Tenda 2 RX
symbol Brunny = B.4 'Tenda 3 RX
symbol Aggie_BZ = B.1 'Tenda 1 Busy
symbol Gertie_BZ =B.3 'Tenda 2 busy
symbol Brunny_BZ = B.5 'Tenda 3 Busy
symbol Baud =T4800 'tenda baud Rate
symbol Trigger =C.1 'trigger, probably PIR
symbol debounce = b1
Init: 'starting point
serout Aggie, Baud, ($EF) 'stop tenda 1
serout Gertie, Baud, ($EF)'stop tenda 2
serout Brunny, Baud, ($EF)'stop tenda 3
pause 10000 'wait 10 seconds
serout Aggie, Baud, ($E8) 'set tenda 1 volume
serout Gertie, Baud, ($E8) 'set tenda 2 volume
serout Brunny, Baud, ($E8) 'set tenda 3 volume
pause 60000 'wait 1 minute
Cauldron: serout Aggie, BAUD, ($E8) 'set Tenda volume
debounce=0
Do
serout Aggie, Baud, ($02) `play Track 2, Folder 1
pause 1000 'give Tenda time to start playing track
if Aggie_BZ = 1 then All_Chant '0=playing, 1=stopped
readadc Trigger,debounce
Loop While debounce<50 ' exit loop if PIR triggered
All_Chant:
pause 500
serout Aggie, Baud, ($01)
serout Gertie, Baud, ($01)
serout Brunny, Baud, ($01)
Do while Aggie_BZ = 0
Early_Early:
serout Aggie, Baud ($F2,01)
do while Aggie_BZ = 0
serout Gertie, Baud ($F2,01)
do while Gertie_BZ = 0
serout Aggie, Baud ($F2,02)
serout Gertie, Baud ($F2,02)
serout Aggie, Baud ($F2,03)
serout Gertie, Baud ($F2,03)
serout Aggie, Baud ($F2,04)
serout Gertie, Baud ($F2,04)
