chipsnfish
I am using a PIC 08 to do the following but don't know how to programme it using picaxe programming editor. Please can you check if it is accurate and makes sense ...and then convert it into a basic program file:
Key Switch on
green led high
siren high 1 sec
tilt switch on? --------no?--------(this goes back to "key switch on")
yes?
red led high 8 secs
siren high 8 secs on low volume
key switch off? --------no?--------(this goes back to "key switch on")
yes?
red led high 30 secs
siren high 30 secs
Then it goes back to Key Switch on!
NOTE: in the attachment the "1" on the IC chip is in the wrong place and also I forgot to drill two holes where the download socket is meant to be. Is there any other info you need? please tell me I will put it up.
Key Switch on
green led high
siren high 1 sec
yes?
red led high 8 secs
yes?
siren high 30 secs
