Garden Irrigator
The bear
Hello,
Suggestions please.
Problem, using 'Toggle'.
Toggle flashes a Led, to indicate water flow. When power (12v) is removed, Led has a 50 50 chance of being OFF, I would like 100%
;IRRIGATION using Buzby timer v1.0a 12.06.19  (Thank you Buzby, Desperate Dans cat).
#picaxe 08m2 ;274 Bytes Toggle C.1 = 12v present
#No_data    ;1 HR delay, ON for 1 Hr, OFF for 2 Hrs, ON  for 1 HR
   ;Resets after 24 Hrs
  Sertxd("IRRIGATION using Buzby timer v1.0a 12.06.19",13,10)
Symbol minutes = w2
Symbol hours   = w3
Symbol valve  = C.2 'was C.4
Symbol valveSupplyLed = C.1
Symbol valvepower = pinC.3
' Start of code
minutes  = 0
hours  = 0
Do
 Do ' Hours loop
  time = 0     ' Reset in-built seconds counter
  Do ' Minutes loop
 If valvepower = 0 Then '+12v present was = 1
   Toggle valveSupplyLed 'Flash Led
 Endif
   Pause 1000
   ;Sertxd (#hours,":",#minutes,":",#time,Cr,Lf)  'Com'd out when in use.
  Loop Until time > 59 ' *** Should be 59 for one minute
  minutes = minutes + 1
 Loop Until minutes > 59 ' *** Should be 59 for one hour
 hours = hours + 1
 minutes = 0
 If hours = 1 Then
  Sertxd ("Valve operated ON",Cr,Lf)
  High valve        ' Operate Valve ON for 1 Hour
 Endif
 If hours = 2  Then  ;was 24 ( 12 hrs, Spot on) No Sertxd line 20
  Sertxd ("Valve operated OFF",Cr,Lf)
  Low valve 'Valve OFF
 Endif
 If hours = 4  Then  ;was 24 ( 12 hrs, Spot on) No Sertxd line 20
  High valve 'Valve OFF
 Endif
  If hours = 5  Then  ;was 24 ( 12 hrs, Spot on) No Sertxd line 20
 Endif
 If hours = 24  Then  ;was 24 ( 12 hrs, Spot on) No Sertxd line 20
Reset 'Every 24 Hours
 Endif
Loop
lbenson
Why not (if I understand what you're asking--blink if 12V present, OFF if not present)
If valvepower = 1 Then '+12v present was = 1
   toggle valveSupplyLed 'Flash Led
Else
  low valveSupplyLed
Endif
Perhaps you also want a "low valveSupplyLed" after "low valve"
If your code had indentation, you can preserve it by going back and enclosing it between the [ code] and [ /code] tags (without the spaces). That would make your code structure easier to understand.
The bear
@ Ibenson,
I had trouble loading my code. Original is indented. Kept getting all the colour info.
I selected all, then clicked 'for forum' then pasted into code/ code. Will try harder.
My problem, When the power is removed from the water valve, sometimes the toggled Led is off, equally sometimes is on, not toggling, but on.
bear..
Buzby
.. I had trouble loading my code. Original is indented. Kept getting all the colour info.
I selected all, then clicked 'for forum' then pasted into code/ code. ...
I had the same problem with 'Paste for Forum', it displayed as formatting text, not coloured text.
So I just did a normal copy, then pasted between the code tags. Came out B&W, but with indents as expected.
I'll do some playing in the sandbox, might find a solution.
Cheers,
Buzby
EDIT : Sorted ! See the sandbox.
I hope you won't mind the intervention but I took the liberty of editing your code tags for you.
[code]...[/code] is what one usually wants, [code=rich]...[/code] if it includes syntax colouring commands.
Using [icode]...[/icode] is what puts boxes around things like this. I thought that might be really useful, especially where I would normally just use uppercase for command names, such as with SERTXD, but I feel it just doesn't look or feel right, is too disruptive in paragraphs with a number of those included.
The bear
@ Ibenson,
As I see it; In the "Timed switch position" , with the Fet Off, +12v will be present. So pinC.3 = 1 which = No toggle.
I only want the Led flashing when the valve is grounded and therefore on. (Hope I've got that right).
Thanks for your interest and help.
I could be on the verge of a meltdown.
lbenson
This looks to me like one way of doing. Note that all statements within a block (DO ..., IF ..., etc.) are indented. (Personally, I prefer to indent each block 2 spaces.)
  #Com 3   ;Resets after 24 Hrs
  Symbol minutes = w2
  Symbol hours   = w3
  Symbol valvesupplyled = C.1
  ' Start of code
  minutes  = 0
  hours  = 0
  Do
   Do ' Hours loop
    Do ' Minutes loop
       if hours = 1 or hours = 4 then
         Toggle valvesupplyled 'Flash Led
     Endif
     Pause 1000
   hours = hours + 1
   minutes = 0
   If hours = 1 or hours = 4 Then
   Endif
   if hours = 1 or hours = 5 then
     low valvesupplyled
   Endif
   Endif
  Loop
The bear
@ hippy,
Thank you.
I've been playing in the Sandbox that long, the tide came in and flattened my sand castle.
The bear
Hi BESQUEUT,
Good to hear from you.
Just a small update, Pulsout works fine.
Regarding code / code, most people don't seem to have trouble with it.
On the whole, the forum/ PE6 works brilliantly.
BESQUEUT
23021
[color=Green]'Sonnette[/color]
[color=Navy]#no_data
#picaxe [/color][color=Black]20M2[/color]
[color=Green]' Port serie ? 4800 bauds pour 4Mhz[/color]
[color=Blue]do
      if [/color][color=Purple]pinc.0[/color][color=DarkCyan]=[/color][color=Navy]0 [/color][color=Blue]then
            sertxd([/color][color=Red]"coucou"[/color][color=Black],[/color][color=Navy]13[/color][color=Black],[/color][color=Navy]10[/color][color=Blue])
            play b.6[/color][color=Black],[/color][color=Navy]3[/color][color=Black],[/color][color=Navy]%10000000
      [/color][color=Blue]endif
loop[/color]
The Post for Forum issue has been noted. In the meantime, changing the [code] tag put at the start of what is pasted to [code=rich] will resolve the display issue.
I suspect posting code hasn't been that problematic due to people using the more familiar Ctrl-C then Ctrl-V sequence to copy and paste, using manually inserted [code]...[/code] tags.
