First and foremost, I am highly impressed with the quality of the programming editor software (complaints or suggestions always sound louder than praise).
Once the software is running, it keeps the serial port open. I'm interested in using the PICAXE as an intermediate device between a piece of Windows software and some external device, so have to close the PICAXE software then reopen it each time I want to test my circuit and/or software.
A workaround I've found is to switch the editor to an unused COM port (eg my modem on COM3); however, the programming editor seems very slow to apply settings (30-40 seconds). This delay is also evident at software startup. I'm not sure if this is a problem with my particular system or not (I have a number of development tools installed).
I'm not sure how your code is structured, so I don't know how easy it would be only open the COM port when it's needed (eg terminal sessions or downloading a program). I fully appreciate that keeping the port open is standard behaviour for applications that use COM ports, and I don't want really to cause extra work for you!
As an aside, I notice that the compilers are available as standalone applications in the Programming Editor's installation directory, and these can (as far as I can see) be used to generate an object file. Is the protocol for downloading programs to a PICAXE available? (Again, I can appreciate that you might not want it to be, though the thought of one PICAXE programming another at runtime would be interesting).
Thanks for reading.
Thanks for reading.
