Forward & Reverse switching?
JPB33
I'm working on a forward and reverse switch for a lathe using a 20M2. I've got this code working but I've hit a brick wall in my knowledge so I'm asking for advice.
input C.0 high is forward and C.1 high is reverse. The outputs are B.0, B.1 and B.3 which drive relays which is also works fine as does the closedown sequence when forward or reverse is switched off.
What I want to do is stop reverse being energised after being selected whilst forward is still closing down else both directions are working for a short time which isnt good!
I dont think I can use gosub as I'm not sure what direction will be selected first so its not a routine?
I would be grateful if someone can point me in the right direction or even understand my explanation! Thanks
   start:
	low B.0
	loop	until pinC.0 = 1 ; PinC.0 high to operate
	high B.0
	if pinc.0 =0 then
	goto start
	high B.2
	loop until pinC.0 = 0
	low B.2
	pause 2000
	low B.0
	goto start
start1:
	low B.1
	loop	until pinC.1 = 1 ; PinC.1 high to operate
	high B.1
	if pinC.1 = 0 then
	low B.1
	goto start1
	high B.2
	loop until pinC.1 = 0
	low B.2
	pause 2000
	low B.1
	goto start1
BESQUEUT
What are supoosed to do B.0, B.1 and B.2 ?
Note that there is no B.3 in your code...
Simply add
low B.1 before high B.0
and
low B.0 before high B.1
Your program is supposed to deal with short press/long press(more than 1s...) but you are not saying what you want your program to do...
My suggestion, without any GOTO command (maybe you know that I hate the GOTO command...) :
[color=Black]start:[/color]
[color=Blue]do
      pause [/color][color=Navy]1000
      [/color][color=Blue]low B.0
      loop  until [/color][color=Purple]pinC.0 [/color][color=DarkCyan]= [/color][color=Navy]1 [/color][color=Green]; PinC.0 high to operate
      [/color][color=Blue]low B.1 [/color][color=Black]: [/color][color=Blue]high B.0
      [/color][color=Blue]if [/color][color=Purple]pinc.0 [/color][color=DarkCyan]=[/color][color=Navy]1 [/color][color=Blue]then
            high B.2
            loop until [/color][color=Purple]pinC.0 [/color][color=DarkCyan]= [/color][color=Navy]0
            [/color][color=Blue]low B.2
            pause [/color][color=Navy]2000
start1:
      loop  until [/color][color=Purple]pinC.1 [/color][color=DarkCyan]= [/color][color=Navy]1 [/color][color=Green]; PinC.1 high to operate
      [/color][color=Blue]low B.0 [/color][color=Black]: [/color][color=Blue]high B.1
      [/color][color=Blue]if [/color][color=Purple]pinC.1 [/color][color=DarkCyan]= [/color][color=Navy]0 [/color][color=Blue]then
            low B.1
            high B.2
            loop until [/color][color=Purple]pinC.1 [/color][color=DarkCyan]= [/color][color=Navy]0
loop[/color]
What I think you need that you haven't written about is a device to detect when the lathe is no longer rotating.
Then it doesn't matter which direction is the "new" direction.
Per Tex, the right way to do it is to have a rotary sensor to detect when the lathe has stopped. If no such sensor is available, you could just run some empirical tests to determine how long it takes your lathe to coast to a stop. Safest bet is to use the worst case scenario of max RPM turning a heavy load which acts like a flywheel and take longer to spool down. Whatever that interval is, program a PAUSE for that many seconds before restarting in the opposite direction. No pause is necessary if the restart is in the same direction of rotation previously used (you'll store/update the last direction as a variable for reference).
If this is a brushed DC motor you could get fancy with an extra relay and do some dynamic braking to slow the lathe down faster. Basically temporarily hooking a low-value, high-power resistor across the two motor terminals.
JPB33
Thanks everyone for the helpful comments, I should have explained it better but pleased I posted my problem as its lead to a solution! To explain further C.0 and C.1 are 5v inputs from the modified existing F&R switch. Outputs B.0 B.1 energise relays replacing the F&R switch, B.2 switches the inverter on. The relays are driven by darlington transistors.
The sequence of events is input C.0 high to select forward, B.0 goes high, contactors in, then a delay and goes B.1 high to start inverter. Lathe now running forward.
Switch off B.2 off first, inverter stops motor slows and stops, B.1 off after delay, contactors out. Then other the direction can be selected and the sequence repeated in opposite direction. What I wanted was to prevent the opposite direction being selected before the initial sequence finished and the motor stopped.
I want to use the existing control gear which works fine, but also wanted to allow time for the inverter to ramp up after the direction was selected. the motor is three phase 7.0 hp two speed (1440 & 2880 rpm) I had thought about using a rotation sensor on the motor but havent got that far yet, was going to determin the time delay (going to make it adjustable) after some test and may be enough bearing in mind the lathe dates from 1968 and its survived so far. Some lathes I've seen use dynamic braking with dc injection to the motor which gives good results.
My good friend The Bear has come up with a gosub routine that I couldnt get working so I think the problem is solved for now--many thanks
#Picaxe 20M2
#No_Data
output B.0,B.1,B.2,B.3,B.4,B.5,B.6,B.7
input C.0,C.1,C.2,C.3,C.4,C.5,C.6,C.7
Symbol SwitchFor = pinC.0
Symbol SwitchRev = pinC.1
Main:
low B.0, B.1,B.2
if SwitchFor = 1 then
Gosub FOR_WARD
if SwitchRev = 1 then
Gosub REV_ERSE
FOR_WARD:
high B.0
if SwitchFor =0 then
high B.2
loop until SwitchFor = 0
low B.2
pause 3000
REV_ERSE:
high B.1
if SwitchRev = 0 then
low B.1
high B.2
loop until SwitchRev = 0
low B.2
pause 3000
I think what you need is a Finite State Machine (FSM). Multi-tasking can be used to set the desired state when a button is pushed and wit until button is released ...
Start0:
    if pinFWD = 1 Then
      desiredState = GO_FWD
      Do : Pause 100 : Loop While pinFWD = 1
And similar for the reverse button.
Then a multi-tasking routine which knows whet state things are in and sequences then to what the desired state should be.
BESQUEUT
Do you mind B.2 high to start inverter ?
It is very dangerous to use a GOTO command within a subroutine. The RETURN command will never be reached, causing unpredictable behavour...
Your code do exactly the opposite :
Il you want to allow time for the inverter to ramp up, you have to switch it first, and after sometime connect the requested motor...
The FSM could look something like this -
Start7:
  Low FWD_MOTOR
  Low BWD_MOTOR
  state = STOPPED
    Select Case state
      Case STOPPED
        If desiredState = GO_FWD Then
          High FWD_MOTOR
          Pause 5000
          state = GO_FWD
        ElIf desiredState = GO_BWD Then
          High BWD_MOTOR
          Pause 5000
          state = GO_BWD
      Case GO_FWD
        If desiredState = STOPPED Then
          Low FWD_MOTOR
          Pause 5000
          state = STOPPED
          Low FWD_MOTOR
          Pause 5000
          High BWD_MOTOR
          Pause 5000
          state = GO_BWD
      Case GO_BWD
          Low BWD_MOTOR
          Pause 5000
          state = STOPPED
        ElIf desiredState = GO_FWD Then
          Low BWD_MOTOR
          Pause 5000
          High FWD_MOTOR
          Pause 5000
          state = GO_FWD
    End Select
    Pause 100
That simply turns on and off the forward motors, waits 5 seconds for them to get up to speed or stop turning. The PAUSE can be replaced or added to with checks the turning has actually stopped.
In this example, if you are going forward ( state = GO_FWD ) and want to go reverse ( desiredState = GO_BWD ), the forward motor is turned off, it waits 5 seconds for it to stop, the backwards motor is turned on, waits 5 seconds for it to be up to speed, then moves into the GO_BWD state. That will then handle the next change of state.
The code could be improved so a change from stopped to forward can be aborted if a change to reverse is seen before the forward motor is up to speed.
Once you have the basics working all sorts of fanciness can be added to improve or optimise its behaviour but getting the basics working reliably and safely is key. Everything else simply builds on that.
JPB33
I've other machinery where the motor is connected to the inverter by a contactor then the inverter is activated (its already switched on) and ramps the motor up to speed, think I described it badly.
BESQUEUT Sorry i'm lost by that statement, be grateful if you can explain it?
HIPPY thanks for the code but it fails syntax with this message
Low FWD_MOTOR
Syntax error on line 2 at/before position 6
Error: This command requires the pin number in format PORT.PIN not PINx!
BESQUEUT
So B.2 starts the ramp process... am I right ?
Why is there a delay between Motor ON (B.0) and start ramp (B.2) ?
Each time the Picaxe encounter a GOSUB, it push on the stack the address where it have to go when the RETURN is reached. At this time, this adress is popped and the stack unfilled.
If the RETURN is not reached, the address stay on the stack, till it become full...
At this point, olders return adress are losts...
As your program always return to Main, it's not a big problem, but it may be if you add others GOSUB in your program.
You will have to define FWD_MOTOR as a symbol to a pin for controlling the motor along with BWD_MOTOR, and other constant names will need defining. You may need to modify for however you have things; it was was more an example of how rather than code to use.
With regard to the code in post #5, I think the "goto main" doesn't fix the problem with mixing "gosub" and "goto". If you continue to do repeated "gosub" without doing a "return" for each, you will run out of stack space and your program will fail.
Something like this would do better:
FOR_WARD:
  high B.0
    high B.2
    low B.2
    pause 3000
Every time you use a "gosub", you must exit the routine (sooner or later) with a "return" (unless you issue a "reset", which would reinitialize the stack counter--not recommended unless you have a specific need).
BESQUEUT
To be exact, the simulator will fail with a superb "Stack Overflow" message
[color=Navy]#Picaxe [/color][color=Black]O8M2
Main:
      [/color][color=Blue]inc [/color][color=Purple]b0
      [/color][color=Blue]sertxd([/color][color=Black]#[/color][color=Purple]b0[/color][color=Black], [/color][color=Red]" "[/color][color=Blue])
      gosub [/color][color=Black]SubRoutine[/color]
[color=Blue]goto [/color][color=Black]Main
SubRoutine:
      [/color][color=Blue]GOTO [/color][color=Black]Main
      [/color][color=Blue]RETURN[/color]
But a real Picaxe will survive ! (and a day or other do stranges things...)
as explained #11
JPB33
To allow the contactors time to come in also to allow for any operator error in case he changes his mind on direction the input state is checked again. and ramping the inverter can be aborted at that point and evrything returns to off.
I just ran #14 and I got it to 9 before it crashed? Just ran #5 and also got 9 before overflow if I aborted early so I see your point. Is there and easy way to monitor the stack overflow to see when it critical?
So return is safe and its only when the loop terminates early with a gosub?
Lots of learning for me---dont forget I'm only a novice with no programming background. I only know what I've learned with picaxe over the last few years so its been great! Thanks
BESQUEUT
So return is safe and its only when the loop terminates early with a gosub ?
If you are not using the GOTO command, you merely can not go out a subroutine without reaching the RETURN command...
So, my best advice (at least for a novice) is : DO NOT USE THE GOTO COMMAND
==> your code will be more readable,
==> the simulator will not crash with stack overflow,
==> real Picaxe will not have unpredictable behaviour...
The solution is not to "goto" out of a subroutine. You must write the code so that every "gosub" is matched with a "return" in the actual execution of the code. The easiest way to do this is to write your code so that you don't use "goto" at all. With the "block" commands like "do .. loop", "for ... next", and "gosub ... return" (and also "if"), this is not hard to do. It may take some consideration to get it right, but it will help you to avoid errors like the one you are encountering.
JPB33
Ok point taken. Replaced the goto in #5 with return and it runs fine and cannot make it crash with the stack overflow message.
In this instance its doing the same job?
Is that a safe fix?
Is there a way to monitor stack overflow with the program running or is it within the make up of the chip?
Thanks
BESQUEUT
Here is my contribution for a state machine:
[color=Navy]#Picaxe [/color][color=Black]20M2[/color]
[color=Navy]#No_Data    [/color]
[color=Blue]output B.0[/color][color=Black],[/color][color=Blue]B.1[/color][color=Black],[/color][color=Blue]B.2[/color][color=Black],[/color][color=Blue]B.3[/color][color=Black],[/color][color=Blue]B.4[/color][color=Black],[/color][color=Blue]B.5[/color][color=Black],[/color][color=Blue]B.6[/color][color=Black],[/color][color=Blue]B.7
input C.0[/color][color=Black],[/color][color=Blue]C.1[/color][color=Black],[/color][color=Blue]C.2[/color][color=Black],[/color][color=Blue]C.3[/color][color=Black],[/color][color=Blue]C.4[/color][color=Black],[/color][color=Blue]C.5[/color][color=Black],[/color][color=Blue]C.6[/color][color=Black],[/color][color=Blue]C.7
Symbol [/color][color=Purple]SwitchFor [/color][color=DarkCyan]= [/color][color=Purple]pinC.0[/color]
[color=Blue]Symbol [/color][color=Purple]SwitchRev [/color][color=DarkCyan]= [/color][color=Purple]pinC.1[/color]
[color=Blue]Symbol Motor_Forward[/color][color=DarkCyan]=[/color][color=Blue]B.0
Symbol Motor_Backward[/color][color=DarkCyan]=[/color][color=Blue]B.1
Symbol Ramper[/color][color=DarkCyan]=[/color][color=Blue]B.2
Symbol Active[/color][color=DarkCyan]=[/color][color=Navy]1[/color]
[color=Blue]Symbol RelayDelay[/color][color=DarkCyan]=[/color][color=Navy]1 [/color][color=Green]'s[/color]
[color=Blue]Symbol RampDelay[/color][color=DarkCyan]=[/color][color=Navy]5 [/color][color=Green]'s[/color]
[color=Blue]Symbol RunningDelay[/color][color=DarkCyan]=[/color][color=Navy]20 [/color][color=Green]'s[/color]
[color=Blue]Symbol StoppingDelay[/color][color=DarkCyan]=[/color][color=Navy]6 [/color][color=Green]'s[/color]
[color=Blue]symbol [/color][color=Purple]Direction[/color][color=DarkCyan]=[/color][color=Purple]b1[/color]
[color=Blue]symbol UP[/color][color=DarkCyan]=[/color][color=Navy]1[/color]
[color=Blue]Symbol DOWN[/color][color=DarkCyan]=[/color][color=Navy]2[/color]
[color=Blue]Symbol [/color][color=Purple]State[/color][color=DarkCyan]=[/color][color=Purple]b2[/color]
[color=Blue]Symbol Stopped[/color][color=DarkCyan]=[/color][color=Navy]0[/color]
[color=Blue]Symbol BeforeRamp[/color][color=DarkCyan]=[/color][color=Navy]1[/color]
[color=Blue]Symbol Ramping[/color][color=DarkCyan]=[/color][color=Navy]2[/color]
[color=Blue]Symbol Running[/color][color=DarkCyan]=[/color][color=Navy]3[/color]
[color=Blue]symbol Stopping[/color][color=DarkCyan]=[/color][color=Navy]4[/color]
[color=Blue]symbol StopThenRamp[/color][color=DarkCyan]=[/color][color=Navy]5[/color]
[color=Black]Main:
      [/color][color=Blue]low B.0[/color][color=Black], [/color][color=Blue]B.1[/color][color=Black],[/color][color=Blue]B.2
      [/color][color=Purple]Direction[/color][color=DarkCyan]=[/color][color=Blue]Stopped
      [/color][color=Purple]State[/color][color=DarkCyan]=[/color][color=Blue]Stopped
      [/color][color=Purple]Time[/color][color=DarkCyan]=[/color][color=Navy]0
      [/color][color=Blue]do
            if [/color][color=Purple]SwitchFor[/color][color=DarkCyan]=[/color][color=Blue]Active then
                  if [/color][color=Purple]switchRev[/color][color=DarkCyan]=[/color][color=Blue]ON then [/color][color=Green]' Hey Dude ! What are you doing ?
                        [/color][color=Blue]GOSUB [/color][color=Black]GoStop
                  [/color][color=Blue]else
                        GOSUB [/color][color=Black]GoUP
                  [/color][color=Blue]endif
                  if [/color][color=Purple]switchRev[/color][color=DarkCyan]=[/color][color=Blue]Active then
                        GOSUB [/color][color=Black]GoDOWN
            GOSUB [/color][color=Black]LookAtWatch
      [/color][color=Blue]loop
                  [/color]
[color=Black]GoUP:
      [/color][color=Blue]select case [/color][color=Purple]Direction
      [/color][color=Blue]case Stopped
            high Motor_Forward
            [/color][color=Purple]state[/color][color=DarkCyan]=[/color][color=Blue]BeforeRamp [/color][color=Black]: [/color][color=Purple]Time[/color][color=DarkCyan]=[/color][color=Navy]0
      [/color][color=Blue]case DOWN
            low Motor_Backward
            [/color][color=Purple]state[/color][color=DarkCyan]=[/color][color=Blue]StopThenRamp [/color][color=Black]: [/color][color=Purple]Time[/color][color=DarkCyan]=[/color][color=Navy]0
      [/color][color=Blue]endselect
      [/color][color=Purple]Direction[/color][color=DarkCyan]=[/color][color=Blue]UP
      RETURN
      [/color]
[color=Black]GoDOWN:
            high Motor_Backward
      [/color][color=Blue]case UP
            low Motor_Forward
      [/color][color=Purple]Direction[/color][color=DarkCyan]=[/color][color=Blue]DOWN
      RETURN
      [/color]
[color=Black]GoStop:
      [/color][color=Blue]low Motor_Forward[/color][color=Black],[/color][color=Blue]Motor_Backward[/color][color=Black],[/color][color=Blue]Ramper
      if [/color][color=Purple]Direction [/color][color=DarkCyan]<> [/color][color=Blue]Stopped then
            [/color][color=Purple]State[/color][color=DarkCyan]=[/color][color=Blue]Stopping [/color][color=Black]: [/color][color=Purple]Time[/color][color=DarkCyan]=[/color][color=Navy]0
      RETURN
      [/color]
[color=Black]LookAtWatch:
      [/color][color=Blue]select case [/color][color=Purple]State
      [/color][color=Blue]case BeforeRamp
            if [/color][color=Purple]Time[/color][color=DarkCyan]>[/color][color=Blue]RelayDelay then
                  high Ramper
                  [/color][color=Purple]State[/color][color=DarkCyan]=[/color][color=Blue]Ramping [/color][color=Black]: [/color][color=Purple]Time[/color][color=DarkCyan]=[/color][color=Navy]0
      case Ramping
            if [/color][color=Purple]Time[/color][color=DarkCyan]>[/color][color=Blue]RampDelay then
                  [/color][color=Purple]State[/color][color=DarkCyan]=[/color][color=Blue]Running [/color][color=Black]: [/color][color=Purple]Time[/color][color=DarkCyan]=[/color][color=Navy]0
      case Running
            if [/color][color=Purple]Time[/color][color=DarkCyan]>[/color][color=Blue]RunningDelay then
      case Stopping
            if [/color][color=Purple]Time[/color][color=DarkCyan]>[/color][color=Blue]StoppingDelay then
      endselect[/color]
BESQUEUT
Is that a safe fix?
Probably, but please publish your code between
 ...[ /CODE] tags
[QUOTE="JPB33, post: 299163"]Is there a way to monitor stack overflow with the program running or is it within the make up of the chip?[/QUOTE]
No (and it depend from the Picaxe model...) The problem is inherent for all languages, and Picaxe BASIC of course.
With VB.NET 2010,  GOSUB is no longuer supported ...
VB6 will crash at first loop :
[CODE]
Private Sub Command1_Click()
Main:
    For i = 1 To 100
        Me.Caption = i
        DoEvents
        GoSub Toto
    Next i
    GoTo Fin
Toto:
    GoTo Main
Fin:
End Sub
JPB33
Thanks everyone for your comments. This is the latest version with all goto's eliminated--how safe is this one?
  #Picaxe 20M2
	#No_Data
Main:
	low B.0, B.1,B.2
Gosub FOR_WARD
Gosub REV_ERSE
FOR_WARD:
	high B.0
	high B.2
	low B.2
	pause 3000
	low B.0
REV_ERSE:
	high B.1
	low B.1
	high B.2
	low B.2
	pause 3000
	low B.1
BESQUEUT
  #Picaxe 20M2
	#No_Data
Main:
	low B.0, B.1,B.2
Gosub FOR_WARD
Gosub REV_ERSE
FOR_WARD:
	high B.0
	high B.2
	low B.2
	pause 3000
	low B.0
REV_ERSE:
	high B.1
	low B.1
	high B.2
	low B.2
	pause 3000
	low B.1
IMHO, this one is safe and do the job. BRAVO !
JPB33
Following on from the ealier postings now got the F&R switch working. Initially it was running on a 20m2 but realised I could use an 8m2 so converted the code and it works fine apart from earlier downloading issues which are now solved.
It runs fine in simulation also in the real world unless its in put into forward direction ie pin C.5 serial input high then powered up when it just flashes the o/p led. If C.5 is switched low and then high with the power on it works normally so it looks like I'm up setting something to do with C.5 serial input although I'm using disconnect?
Tried moving the disconnect command without success.
#Picaxe 08m2
#No_Data
Disconnect;
output C.0,C.1,C.2
input C.3,C.4,C.5
Symbol SwitchFor = pinC.5
Symbol SwitchRev = pinC.3
Symbol Inc_counter = b1
symbol Del_ay = b2
Main:
readadc C.4,Del_ay
low C.0, C.1,C.2
b1 = 0
pause 100
if switchfor=1 then
Gosub FOR_WARD
pause 100
if switchRev=1 then
Gosub REV_ERSE
FOR_WARD:
high C.0
high C.2
low C.2
readadc C.4, Del_ay
Inc inc_counter
pause 20
loop until Inc_counter >= Del_ay
low C.0
b1 = 0
REV_ERSE:
high C.1
low C.1
high C.2
low C.2
readadc C.4, Del_ay
Inc inc_counter
pause 20
low C.1
b1 = 0
C.5 ( Serial In ) must be kept low when the PICAXE is powered up or it will think there is a download being initiated and the program will not execute.
