Is it permissible to exit a for / next loop before it has completed?
For instance, a condition could be met ( if...then ) halfway through the loop count. Could I use a goto in this case and leave the for/next in limbo, or should I use a gosub so that I return to the loop to clean up the dregs. What if I want to re-run the loop later in the programme?
I just love this, everytime you crack a problem, another one arises.
Regards,
Russ
Regards,
Russ
