joe paul
Hi Folks,
I want to duplicate the circuit I just did on the AXE002 board, and I don't need more than 1 input and 3 outputs, with this 18M2. I intend to program the chip on another board then put the 18M2 chip in a socket on the homemade board. I don't need the full Darlington array, so there will only be 2 transistors, and the Mosfet for the outputs (with the necessary resistors for the 3). The only input will be from the HC-06 module.
Do I have to keep the pins I am not using pulled down with a resistor or can they float?
With the inputs for the programming cable, if I won't be programming the chip on this board, do I do anything with those pins?
I am trying to make the circuit as compact as possible.
Thanks!
Take care, Joe.
Thanks!
Take care, Joe.
