This error usually occurs when a command is used which is supported by latest firmware but not by the firmware in the chip being programmed.
Not sure what command is causing that issue; it looks like RUN from what your report says but I don't get that error message when I test that. Perhaps post your program and do a Firmware Check to identify what Firmware you do have.
