I want to have PWM signal out from my 08M on pin 2 from i set power it to i turn it offSorry, but I don't understand your question.
Please explain in more detail what you want to do.
(maybe use plain English rather than a code example)
Yes that help a lot, it was the answer i look forPWMout will run in the background - once you have used a 'pwmout' command, it will keep running until the end of the program, or until you tell it to stop.
Does that help - I don't understand your question.
Andrew
thx for the fast respondpwmout 2, 99, 0 or low 2 are the simplest ways.
