Hi technical
I have three picaxe 18A`s which will not respond to the program editor they will not respond to a download or a firmware check it just returns error hardware not found on COM 5, And they will not respond to a hard reset, The first one failed after a planed clear hardware memory, using anther 18A in its place worked fine. The second one failed after a accidental clear hardware memory I always check syntax before downloading code and clicked clear hardware instead of syntax by mistake using another 18A in its place and that worked fine and the last one failed in the same manner. The three failed 18A`s have been tested in other boards with no response it seem strange to me that they have all failed using clear hardware memory when its only supposed to over right the code. Any comments will be appreciated.
Regards Hazeleb.
Regards Hazeleb.
