Never be afraid to ask a question. It's just that sometimes designers are
like chefs, get more than one in a kitchen and there are different ideas!
Beaniebots: 1mA was chosen as a comparison point, ideally you don't want any conduction until just past the max voltage used. Normal zeners start conducting before their rated voltage, which causes the interference you
claimed, I was not clear on that. TVS will not conduct at all, early, if
you select the correct device. I believe that 5.6V TVS will not cause any
preconduction on a 5V signal. It is like THERE IS NOTHING CONNECTED TO THE ANALOG LINE, until the signal exceeds the clamp level. Sure there is a little stray C and L, but who cares, we need protection.
These devices are used by the millions
on analog signals. I have worked for Allen Bradley, various medical eqpt companies, the military out at Sandia in NM, and on untold dozens of industrial
and space circuits that use this technique. If clamping did not work, our real world circuits would not survive. In space, transients are induced by energetic particles and cosmic rays.
It is notable to describe the lengths necessary to protect military units
from the EMP of a nuke blast (also check out TEMPEST). Very high voltages are impressed on any
leads coming out, and it actually goes thru slots in the case, if there
are any. A slot electrically is just like an antenna. Each lead has to have
a ferrite bead on it right when the wire comes in. Also at that point
a capacitor bypasses it to the case. Finally, a fast solid state diode finishes the job. If you look at MOV clamps you will have a seizure, as they clamp
at twice the rated voltage. One lab I saw fired 12' lightning bolts at a bomb,
there is a trick to stop it from entering connectors, and dissipate over the
surface. In that case you need a little inductance in series with the line
to slow the rate of rise of current, so the clamps have a chance to activate.
Another reason bombs don't go off from lightning, is the firing systems are
very high voltage. You don't want a 12VDC triggered 1MT bomb!
