I am using the ERF wizard to change the baud rate to 2400. I managed after several attempts to do one module,but when I plugged the second ERF module in,(keeping the exact same settings) I keep getting the message: Starting ERF configuration... trying 9600 baud.... Entering command mode. Failed to enter command mode. Unable to communicate with ERF module. I am using a serial cable,so not sure if its a voltage issue.
