Running this as a simulation, not tried on the picaxe itself yet (lcd no longer working; apparently hooking it up to 12V supply kills the right hand side of the screen, so I can only see 8 digit numbers on each line now...)
The code below should read 2 consecutive eeprom addresses into a word variable. Sometimes it does this correctly, sometimes it appears to make up a value that isn't like anything in any eeprom address.
For instance, when b0 = 5, b2,b3 should be 00000001,00010000.
And indeed that is what is returned to these variables.
On the other hand, when b0 = 10, b2, b3 should be 00000010,00000010,
but is apparently 00001010,00001010 instead; these are not even values stored somewhere else in eeprom.
Surely either this code should work, or not work? Why the extra phantom '1's??
#picaxe 08m2
EEPROM 2, (00000001,00000001, 00000001,00000010, 00000001,00000100, 00000001,00001000)
EEPROM 10,(00000001,00010000, 00000001,00100000, 00000001,01000000, 00000001,10000000)
EEPROM 18,(00000010,00000001, 00000010,00000010, 00000010,00000100, 00000010,00001000)
EEPROM 26,(00000010,00010000, 00000010,00100000, 00000010,01000000, 00000010,10000000)
EEPROM 34,(00000011,00000001, 00000011,00000010, 00000011,00000100, 00000011,00001000)
EEPROM 42,(00000011,00010000, 00000011,00100000, 00000011,01000000, 00000011,10000000)
EEPROM 50,(00000100,00000001, 00000100,00000010, 00000100,00000100, 00000100,00001000)
EEPROM 58,(00000100,00010000, 00000100,00100000, 00000100,01000000, 00000100,10000000)
EEPROM 66,(00000101,00000001, 00000101,00000010, 00000101,00000100, 00000101,00001000)
EEPROM 74,(00000101,00010000, 00000101,00100000, 00000101,01000000, 00000101,10000000)
EEPROM 82,(00000110,00000001, 00000110,00000010, 00000110,00000100, 00000110,00001000)
EEPROM 90,(00000110,00010000, 00000110,00100000, 00000110,01000000, 00000110,10000000)
EEPROM 98,(00000111,00000001, 00000111,00000010, 00000111,00000100, 00000111,00001000, 00000111,00010000)
init:-
pause 50
serout C.2,N2400,(254,1)
pause 500
serout C.2,N2400, (254,128)
serout C.2,N2400, (#b0) 'puts N on lcd
b0 = 9 'SHOULD BE:- b0 = 10: 00000010,00000010; b0 = 5: 00000001,00010000
b1 = 2 * b0 'IS b0 = 10: 00001010,00001010; b0 = 5: 00000001,00010000
read b1, WORD w1
serout C.2,N2400, (254,192)
serout C.2,N2400, (#b2, #b3)
