Reloaded Win7 and picaxe editor, etc onto new HD in same PC I've done all previous picaxe work on.
Followed instalation instructions, axe027_installer failed for unknown reason, so manually added drivers on all my usb ports (port numbers 3-6.)
Axe027 currently plugged into USB port with address '00000003'.
Looking for 'axe027' in device manager, I find it under 'usb controllers', but it has no COM port number. It tells me it has driver version 2.8.14.0 installed, and is 'working correctly.'
I've read other threads here similar to mine, like where westaust55 suggests:-
1. Select Options/Serial Port
2. If you see the AXE027 (or other) download cable select it
3. If do not see the AXE027 cable select the tick box "Show Port Help Tools..." then, click "Scan for USB cable" which will show you which port to select.
My editor has no "Show Port Help Tools..."
How do I get the editor to recognise the cable??
Thanks.
Thanks.
