Strider100
On uploading the new editor to my now win 10 machine I find that:
I am unable to syntax check any chips other then 08M2 and 18M2 - the editor freezes and the only way to get out is to use task manager.
I also cannot run the simulator which just freezes the whole editor. The controls go grey so you can't stop the simulation, if you try to close then a message saying unable to do whilst simulator running comes up.
I have had problems with other software and Win 10 which seems to be connected with the fact I did an update rather than a clean install of win 10. However these other issues have been resolved so i am reluctant to do a full clean install of win 10 unless I really have to.
Program editor 5.5.6 appears to work OK. on my win 10.
Edit:
After some extensive trying I find the following:
A simple program -
Start:
for b1=1 to 10
wait 1
next b1
end
This should run on all picaxe chips.
It will only syntax check (and therefore simulate) on the 08m2 and the 18M2
turning prp processing off does not help.
On all other chips selection the syntax check hangs.
Compiler 3.4
Pre processor 1.0.5
Edit:
A simple program -
Start:
for b1=1 to 10
wait 1
next b1
end
Compiler 3.4
Pre processor 1.0.5
