The 18X also has i2c comms. By then, since you will have i2c, you might as well use the DS1307 or DS1338 RTC which are more frequently used with PICAXE chips.I need at least a 28X1 for that, in which case I may as well use the i2c bus.
What exactly is bit-banging? Would this involve the SERIN command?though I2C could be bit-banged.
