Others will correct me if I am wrong, but you cant use port c for this function. You are fairly limited to making port c outputs high or low, ie no pulse function etc. You will need to connect the 18b20 to the set output only ports.Help Please
Can I connect the output of the DS18B20 to any pin OF A PICAXE
ie If I wanted to read value of the temp sensor from PORTc pin 0 on a PICAXE28x1 would I write:
readtemp 11,b1 (11 being pin 11 , portc input0 of the PICAXE) ?
thanks
groutie
