Ds18b20
Groutie
Help Please
Can I connect the output of the DS18B20 to any pin OF A PICAXE
ie If I wanted to read value of the temp sensor from PORTc pin 0 on a PICAXE28x1 would I write:
readtemp 11,b1 (11 being pin 11 , portc input0 of the PICAXE) ?
thanks
groutie
Texy
Help Please
thanks
groutie
Others will correct me if I am wrong, but you cant use port c for this function. You are fairly limited to making port c outputs high or low, ie no pulse function etc. You will need to connect the 18b20 to the set output only ports.
Texy
On a 28X1, port C is the default input port.
For a DSA18B20 connected to physical pin 11, that equates to default input pin 0.
So the command is:
READTEMP 0, b1
or another way:
SYMBOL temp = 0
READTEMP temp, b1
Not a problem.
For the record and by comparison, for a 40X1, the default input port is port D but within the PICAXE programming, the code will not change.
