Hi Paul,
The NPN transistors in #27 have the 560 ohm resistors in their emitters, but the ULN has all the emitters commoned to ground, so you must put the resistors in the collectors.
Normally a "Darlington" has two base-emitter diodes to ground which would need an input resistor, but I see from the data sheet (foot of page 4) that 2k7 resistors are included within the package, so no, you don't need to add them externally (except for the optional PICaxe "safety" resistors to help protect against wiring errors or "screwdriver" short-circuits).
That power supply looks much more suitable than the previous ebay offering, but I'm not sure I'd use it at a full 10 Amps. The efficiency is probably around 90%, and I wouldn't be very happy dissipating 12+ watts in what appears to be a rather small plastics box. Also, the "specification plate" is rather "suspect". I believe that the stated input current should ba a maximum, but at 100 volts that could only put 100 watts in, so you're not going to get 120 watts out!
