Sorry if this is a stupid question...I tried searching but the closest topic/search-result I could find was the "opposite" question (which was "drive multiple LCD's with one PICAXE").
I just started playing around with LCD's for the first time today...I basically made my own "AXE133" with a breadboard, 8x2 LCD, and an extra 18m2 (to drive the parallel LCD) I had. I started with the AXE133 code and now I can get the 18m2 to initialize the LCD and display a welcome message. Very cool!!! Im completely new to microcontrollers and programming in general so I was pretty ecstatic when I flipped the switch and saw ASCII text come up on the LCD.
I still have yet to try hooking up a second "Master" PICAXE to send serial (ASCII) data to the 18m2 slave/LCD driver.
However, it got me wondering...is it possible to have multiple PICAXE "co-processors" send serial data to the single display driver? Maybe put a diode on each of the serial-out pins on each Picaxe so when one Picaxe co-processor sends serial data to the LCD driver, it doesnt "backfeed" into the second Picaxe co-processor.
For example, say I have two Picaxes ("widget A" and "widget B") each doing their own thing/performing their own separate functions. Then the third Picaxe (the AXE133) simply listens to the serial-input and drives the single 8-bit-parallel-LCD. 99% of the time, "Widget A" is sending miscellaneous ASCII text to the LCD...but every once in a while, I want to have "Widget A" shut-up for a couple seconds while "Widget B" sends a line of text to the LCD for a couple seconds...then after that, "Widget B" goes back to doing its own "non-LCD-oriented" thing and "Widget A" goes back to its normal job of sending text to the LCD.....
Does that make sense, what I am trying to do? As long as I make sure that the two Picaxe's are not trying to send serial data to the LCD at the same time (and isolate each serial output so one Picaxe doesnt try to backfeed into the other output), will it work?
thanks,
Ben
thanks,
Ben
