Iam trying to draw rpm realtime graph in c#, but I have strange line drop sometimes. I just noticed it happens when I spin it high and i little bit drop rpm, then it shows like huge drop
Can someone c# guru check if this programm error or picaxe ?
C# 2010 project View attachment RPM.zip
count B.3,1000, w1
sertxd(#w1)
namespace RPM
public partial class Form1 : Form
private const int CHART_SECONDS = 60;
private Series mySerie;
public delegate void AddDataDelegate();
public AddDataDelegate addDataDel;
public Form1()
InitializeComponent();
addDataDel += new AddDataDelegate(AddData);
DateTime minValue = DateTime.Now;
DateTime maxValue = minValue.AddSeconds(CHART_SECONDS);
chart1.ChartAreas[0].AxisX.Minimum = minValue.ToOADate();
chart1.ChartAreas[0].AxisX.Maximum = maxValue.ToOADate();
chart1.ChartAreas[0].AxisX.LabelStyle.Format = "T";
chart1.ChartAreas[0].AxisX.IntervalType = DateTimeIntervalType.Minutes;
chart1.ChartAreas[0].AxisX.Interval = 1;
chart1.ChartAreas[0].AxisX.MajorGrid.LineColor = Color.DarkGray;
chart1.ChartAreas[0].AxisX.MinorGrid.IntervalType = DateTimeIntervalType.Seconds;
chart1.ChartAreas[0].AxisX.MinorGrid.Interval = 10;
chart1.ChartAreas[0].AxisX.MinorGrid.LineColor = Color.LightGray;
chart1.ChartAreas[0].AxisX.MinorGrid.Enabled = true;
chart1.ChartAreas[0].AxisY.Minimum = 0;
chart1.ChartAreas[0].AxisY.Maximum = 1000;
chart1.ChartAreas[0].AxisY.IntervalType = DateTimeIntervalType.Number;
chart1.ChartAreas[0].AxisY.Interval = 50;
chart1.ChartAreas[0].AxisY.MajorGrid.LineColor = Color.DarkGray;
chart1.ChartAreas[0].AxisY.MinorGrid.IntervalType = DateTimeIntervalType.Number;
chart1.ChartAreas[0].AxisY.MinorGrid.Interval = 50;
chart1.ChartAreas[0].AxisY.MinorGrid.LineColor = Color.LightGray;
chart1.ChartAreas[0].AxisY.MinorGrid.Enabled = true;
chart1.Series.Clear();
mySerie = new Series("RPM");
mySerie.ChartType = SeriesChartType.FastLine;
mySerie.BorderWidth = 1;
mySerie.Color = Color.Red;
mySerie.XValueType = ChartValueType.DateTime;
chart1.Series.Add(mySerie);
DateTime timeStamp = DateTime.Now;
chart1.Series[0].Points.AddXY(timeStamp, 0);
private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
chart1.Invoke(addDataDel);
public void AddData()
string stringValue = serialPort1.ReadExisting();
chart1.Series[0].Points.AddXY(timeStamp, (int.Parse(stringValue)*20)/2);
double removeBefore = timeStamp.AddSeconds(-CHART_SECONDS).ToOADate();
while (mySerie.Points[0].XValue < removeBefore)
mySerie.Points.RemoveAt(0);
chart1.ChartAreas[0].AxisX.Minimum = mySerie.Points[0].XValue;
chart1.ChartAreas[0].AxisX.Maximum = DateTime.FromOADate(mySerie.Points[0].XValue).AddSeconds(CHART_SECONDS).ToOADate();
chart1.Invalidate();
private void button1_Click(object sender, EventArgs e)
serialPort1.PortName = "COM7";
serialPort1.BaudRate = 4800;
serialPort1.Open();
if (serialPort1.IsOpen)
buttonStart.Enabled = false;
buttonStop.Enabled = true;
private void buttonStop_Click(object sender, EventArgs e)
serialPort1.Close();
buttonStart.Enabled = true;
buttonStop.Enabled = false;
private void Form1_FormClosing(object sender, FormClosingEventArgs e)
if (serialPort1.IsOpen) serialPort1.Close();
