Having problems downloading. I get the error "Error - Memory Verification Failed (Byte XX)" where XX changes each time. Most of the time I get this error but not always.
Here's the interesting part. If I overclock the chips to 8MHz, the downloads always work.
System:
Experimenter's Board
USB-to-Serial converter cable with proper drivers installed.
Using 5.0.7 program editor.
Firmware version 9.2.
Here's what I've done to debug:
Mostly using 3 fresh AA bateries for power. Multimeter shows 4.6 volts.
Also used a 9V wall wort connected to the 7805 supply.
Doublechecked the board resistor values, positions, and touched up the soldering.
Tried both an 18X and 08M, get same symptoms on both.
Tried different host computers.
Get the same error when using the "Clear Hardware Memory" option.
None of these changes affected the results.
I am generally OK because it works when overclocked. But changing frequency is difficult and it is difficult to clear the memory. The download at 4MHz will work occasionally.
Any ideas?
Thanks,
-- Dan
System:
Any ideas?
Thanks,
-- Dan
