Even though the signal i got from the rectifier was good enough to be used as a switch i ended up making two separate circuits, one with a LED and the (picaxe one) with an LDR, and because the original doorbell casing is completely sealed off when closed, it works fine as a digital on/off switch. I will post an URL here later on when the project is more sucessful for anyone that would be interested.
Basically i connected another picaxe chip with a receiver to a computers serial port and "switched" the traffic over when it was transmitted to the right address. However, today the system "stopped working". And after fiddling alot with the setup, making an extra transmitter and removing anything unecessary, switching input pin etc, on the receiver breadboard, i finally found out it is receiving data, but at such a rate the legitimate stuff is being ignored.
Now finally on to my question; what kind of devices do you guys know of that would be using the 433MHz AM modulated band that could be sending continous data like this? Im thinking portable phones, alarm systems and maybe TV links, as i know alot of my neighbours use. And please if i am way off here let me know, i just want to get to the bottom of it.
