Periodically I get a problem with the AXE027 cable.
In Picaxe Programming Editor - Options - Serial Port. see COM2 (not available) AXE027 PICAXE USB. When I click on "Scan for USB Cable" it says "An AXE027 Download Cable is connected to Com2 but is being used by another application". Close the application using COM2 to use the cable for program downloads.
I have tried rebooting the PC, re-installing the AXE27 driver, but I keep getting the above message.
How can I see which application it thinks is claiming Port2 and are there any tricks to force things COM2 back to normal?
Cheers.
Cheers.
