Digital Audio selection by Picaxe
Digital Voter:
The purpose of this project is use a 28X2 picaxe to choose the strongest audio from three NOAA weather satelite receivers. It works on the basis that the level of audio rises from a low point to a higher point as the satellite receiver rises in the sky until the automatic gain control of the receiver maxes out.
The audio is peak level detected to convert from audio to a varying DC level which is fed to the ADC of the Picaxe. The picaxe then enables one of four switches in a CD4066 to allow the selected audio through to my PC which does the work of decoding the signal, using WXtoIMG software.
The issue I try to resolve is of inaccuracies in my helical antennas that I have made and low signals just over the horizon as the satellite comes into view. Once it is over about 30 degrees over the horizon the strengths are generally very good.
The project uses Nick12AB's bargraph code to display the three varying levels on a LCD display which works on a 4 line parallel LCD - thanks to him for his help and uses the ADCs in the 28X2 for level conversion using a 10 bit resolution.
I have also used the picaxe to have an override switch for my HF Receiver audio when I want to decode RTTY, and other digital modes on my PC. My final design has an override switch for a specific Sat RX R2ZX which has additional filters for NOAA 18 reception which is affecte d by pagers where I live. This is not shown on the circuit as is specific to my needs but just uses the final spare intput and is identical to the HF switch circuitry.
I attach the circuit and the code for your perusal. The code may help some one looking to do something similar, I don't expect too many will receive satelite images from NOAA polar orbiters. I hope it is of interest to some.
You can open the code in PE.
Hamtech
Digital Voter:
Hamtech
