I have recently started using DesignSpark PCB. I downloaded all the PICAXE Create libraries and on my first design I ran into a problem using the the 1N4001 diode in the picaxe_create_components_cml library. Having translated a schematic to PCB and manually moved/connected 2 diodes, DesignSpark complains when I do a design check between the schematic and PCB and wants to reroute the diodes. What I found is that the pin numbers of the diodes in the picaxe create component library are transposed between the schematic and the PCB versions. All of the diodes (1N4001,2 etc) are the same. I have used a diode from the designspark downloads library and that is all okay. I also edited a picaxe create diode for my "user" library and that looks aok but when using the diode (ie "ADD COMPONENT") the pin numbers in the schematic get transposed!
Can anyone advise what is going wrong?
