AlastairD(Aus)
Hi all - just joined the Picaxe forum.
I used to work with electronics all the time but for the last 10 years have done zilch. Now I am retired I am building lots of things for various projects and have adopted the Picaxe as my system and finding it good fun.
I have built and got running a a sampling and display system for temps & voltages in the motorhome I am building. I did this with an 18M2 and an i2c LCD display. All good but I needed more sampling channels and decided to move up to a 28X2. After the necessary changes the code works and the sensor channels are ok. My problem is the i2c communication. I have the correct pins connected, the resistor pull ups ok but it does not work. I can plug in the 18M2 on the breadboard and talk to the display on the i2c bus with no changes and it works.
After reading everything relevant and trying everything I can think of I am fed up. What have I missed? What should I try?
cheers
cheers
