Development Help Tool
Marcwolf
Hi Folks.
When I am designing a circuit using a PicAxe it is sometime difficult to remember what you have used certain inputs and outputs for.
I often design first on scraps of paper, working out how the code will interact with the various pins and their functions.
So I have made this simple XLS spreadsheet that lists the pins on the most common PicAxes so I can make notes etc, and then once I have the basics down as Yes - I do have enough inputs/outputs/function pins for the task I can then design the circuit.
PLEASE NOTE - This is a XLS file. Change the Extension from TXT to XLS to use!!! (Cannot load XLS natively on this forum)
Anyway - Hope it helps some folks
Dave
slurp
I put those notes and comments at the begining of the program... even if it's the only comments the program has ;)
I guess the next part is how this is tied to the hardware! :eek:
best regards,
Colin
