Andrew Cowan
Hi all.
I use a remote 4 channel switching device to control the light on my garden shed.
I bought one reciever (£50), and wired it up to a light, which works. However, I would like to interface one of the other channels to some solar lights, via a PICAXE.
I have taken the transmitter apart, and found it contains a standard 433.92MHz transmitter.
Datasheet: http://www.rfsolutions.co.uk/acatalog/DS069-8.pdf
I have also reverse engineered the circuit diagram and drawn a schematic - the DipTrace file is attached. Rename the .txt file to .dch to open it.
As luck would have it, I have a 433.92MHz reciever left over from another project, and this is the same product line as the reciever. This means that I can recieve the signal.
However, it will need decoding.
So, the problem: I have a serial signal which I need to decode. The RF chips support a maximum of 9600 baud, although I am sure the data transmition is much lower than this, as it only needs to transmit a very small amount of data.
It could be True or Inverted - I am not sure.
What is the best way to find out what the message is, and what baud rate it is? If I could somehow connect it to the computer, I could use the serial terminal and set it at each baud rate, and see what came in. How can I connect it up? The reciever runs at 5V. Can a PICAXE help in finding out what rate is used?
Thanks for your help,
Andrew
Andrew
