Hello.
Generally speaking, with battery power being so clean and free from any PSU noise or ripple, do you need the same decoupling caps in a given design?
Currently, I still use 470n SMD caps on the 1703 SMD regulators I use for PICAXE supply, and 100n caps on the PICAXE chip itself, but not much else.
I had an issue today, with a little battery operated circuit which was working fine, but then not.
Voltages fine on battery and on PICAXE, but unit not working.
Hmmmmmm.
Isolate power, replace power, and away it went - it was a controller crash.
I added a 100uF 6.3v electro across the PICAXE thinking that perhaps there was some kind of nasty on the supply, but I don't really see how, as a battery is about as smooth a supply as you are ever going to get.
What is the general consensus here with respect to decoupling caps on battery powered designs?
Is it advisable to just use the same decoupling caps as I would have on a PSU fed design?
All information gratefully assimilated.
Hmmmmmm.
