Thank you for helping.
I found this
http://www.soselectronic.com/?str=371&artnum=5840 - Its ok?
Can you please explaine how to measure output voltage from motor when I spin it, its 24v 25w motor and I will spin it to get aroud 10v(and if higher?), tried with drill and it took around 1k rpm for 10v, not sure just approximate
-What accuracy is required?
-not critical, minor discrepancy is not crucial
-physically how big is the motor?
-length 8 cm width 7 cm , its hard to disassemble this motor to look inside for coils and magnets, its monolith-made
-how much room do you have for sensors?
-pretty enough
-"I will spin it to produce voltage" if I read this literally, this tells me you intend to motor/spin this motor, which will become a generator, is that what you meant by this statement?
-yes, I will try to charge 12v 3.2A battery(gel cell) with this motor,additional question what diode should I use to charge on generator + wire .
-no datasheet,found in my garage
To someone with nerves of steel
, explaine me this methode
If you watch the motor voltage on a CRO, you'll see a back-EMF spike associated with each commutator pad+brush disconnect. Three spikes per REV I think for a normal three pad armature. So just AC amplify this spike signal and count the spikes-per-second. No encoder hardware required, just an op-amp or transistor amplifier.
Will be very grateful if you provide some schematics how to realise this with 18m2, and why do I need to use amplifier, what wave will look with/without amp?
