M milesdj8 New Member Dec 31, 2004 #1 When I try to run the standard datalogger programme, I get an "error ic2 slave command not supported in this mode" message. I am very new to all this. Can anyone tell me what I am doing wrong? David Miles.
hippy Technical Support Staff member Jan 1, 2005 #2 You've selected a PICAXE Device which doesn't support the commands the Datalogger requires. From the Menu of the Programming Editor, select View, Options, PICAXE-18X and everything should then be okay.
M milesdj8 New Member Jan 1, 2005 #3 Thanks hippy. I hadn't realised that I was using the wrong chip! David
