Hello all, I am having some issues with a darlington circuit. Here is the setup:
08M2 driving the darlington (ULN 2803) which is switching on/off 12VDC vent motors under minimal load.
The 08M2 outputs are going high/low in accordance with the code. The darlington is switching in accordance with the code. The problem is when the pins go low, the darlington is still showing 6.33V at the outputs which means the motors are still running, albeit slowly. I have tried several different darlington chips with the same result, which leads me to believe it is a wiring issue. Should I put resistors between the picaxe outputs and darlington inputs? In manual 3 it shows the circuit without resistors.
thanks in advance for your help.
