Yes I did study Nyquist all those years ago but I didn't fancy building the sort of filter that only a few samples would likely need! I'll check out the Mikro s/w, that sounds interesting. I also just started looking into JAL which also promises to be of interest, but I fear spending time on learning curves and complex debugging rather than design. Which is exactly what Picaxe helps you to avoid. No problem with the staircases, after all that is what the filters are for, so long as they can be kept simple.
I do have a couple of programmer boards, never used, but I'll see what they can do.
I do think that a PIC programmed as a function generator could be of quite some interest, being ultra cheap and very simple to use once programmed.
Thanks for your interest!
