Hi I have a project where I want to position a AC motor using a Omron encoder. Currently I have built the interface to the AC motor drive and can control speed and direction of the motor. What I am having trouble with and want advise is the encoder part.
I have read through all the posts regarding encoders and quadrature encoders. Do these super fast version of code allow you to do other tasks in the picaxe? I need to update an LCD display and control the motor speed and direction, while reading the encoder postion.
The encoder is a Omron 500 ppr encoder. But this is overkill and I probably only need about 50 ppr. Is it possible to use just one channel of the encoder and increment the count on every pulse either up if running the motor forward or down if running the motor backwards?
So basically my questions are:
Is it possible to use a 500 ppr encoder spinning at max 2 revs per second while also updating a LCD display and controlling motor speed and direction?
Is there a way to slow down the 500 ppr encoder to say 50 ppr using a standard IC?
Any advise and thoughts would be much appreciated.
Thanks,
Glenn
Thanks,
Glenn
