Couple of bugs on 28X1
Jeremy Leach
1. If I search, using edit>Find, then click off the find window directly onto the code, then do Edit>Find again I get an error "Form already displayed, can't show modally" and the editor closes immediately after.
2. Using SPIOut command it doesn't recognise MSB_First_L as an in-built constant. I'm just assuming from the manual that it's meant to be pre-defined (and the others too).
I'm using 5.1.1
Edited by - jeremy leach on 20/05/2007 12:21:04
We will look into this, yes they should be predefined, but you can also use the number defined in the manual.
Actually this is a documentation error, it should be
MSBFirst_L
not
MSB_First_L
etc.
These will work as expected.
