Hi folks.
I'm a members of our local inshore lifeboat crew (RNLI) and whilst out on exercise last week, came across an problem that with so much going on, has the potential to cause issues if not acted on.
Basically, every 15 minutes, the crew has to radio in to the coastguard an 'ops normal' call to let them know that everything is okay. Unfortunately, with the best will in the world, time can pass by quickly and what I was looking at was a way of developing a small countdown timer that will activate a flashing led and buzzer. This will be situated on the 'A-Frame' console that will be visible to the crew - especially the helmsman.
It needs to have a bright led indicating that the 15 minutes has elapsed plus it needs to have an audible sound plus needs to be relatively waterproof (or splash proof).
What I'd like to know is what is the best chip to use and what battery voltage would be best suited to working with the buzzer in terms of long life. Is it possible to build into the circuit a low battery led indicator for safety measures.
At the moment, I'm at the exploratory stages but have got good feedback from my colleagues. This circuit could also be used in our all weather boat but timing would be increased to 30 minutes
Many thanks
Declan
Many thanks
Declan
