Hello!
I tried the compilers on a x86 Ubuntu 7.10 installation and also on the eeePC 701 default OS. Everything was fine. I hve a USB2RS-232 cable bought from a local shop using the FTDI module.
I noticed that if I don't save the file as .bas the compilers crash giving me a Segmentation fault (core dumped) message:
Nevertheless it is an excellent work to port the compilers for the linux platform.
I was also able to run the compilers on a FreeBSD 5.4 system using Linux Binary Emulation mode. I can also produce the core dump if I omit the filename extension. I have problems downloading the program though since the compiler reports:
Regards,
Stelios
Same thing is happening on both platforms (PC & eeePC) by both compilers.renos@narnia:~$ picaxe08m -s test
PICAXE-08M Enhanced Compiler. Version 0.1
Copyright (c) 1996-2008 Revolution Education Ltd
All rights reserved.
www.picaxe.co.uk
renos@narnia:~$
Device /dev/cuaa1 is the correct device where I have hooked the serial cable connected with the PicAxe. Message Bad address might means something else then?games# ./picaxe08m -c/dev/cuaa1 -t test.bas
www.picaxe.co.uk
Compiled successfully.
Memory used = 14 out of 256 bytes.
line# 0 col# 0
Error: Can't open port /dev/cuaa1.
(err=14: Bad address)
games#
Regards,
Stelios
