Go here and scroll down to westaust55's most excellent data map:Hi, I am using a 18M2 and am confused over "what" variables I can use... e.g.
'w0 = (also b0,b1)
'w1 = (also b2,b3)
'w2 = (also b4,b5)
'w3 = (also b6,b7)
'w4 = (also b8,b9)
'w5 = (also b10/b11)
'w6 = (also b12,b13)
are there any others I can use ?
Thanks technical... douldn't see that part as it was hidden !A quick look at the right handside 'Code Explorer' in PE6 will always show which variables are available for the currently selected chip.
Hello rq3Go here and scroll down to westaust55's most excellent data map:
http://www.picaxeforum.co.uk/showthread.php?11514-PICAXE-Memory-Map-and-SFR-Details-Chart/page3
To directly answer your question, there are w0 through w13, and their associated bytes and bits. There are also special functions s_w0 through as much as s_w7 (chip dependent).
One of the Finished Project sections is probably the best place to put such things. Westaust55 often puts his stuff in Finished Project - Miscellaneous.I hope the Forum Moderators will give serious consideration to the creation of a permanent message board for valuable resources such as this map.
Hi HippyOne of the Finished Project sections is probably the best place to put such things. Westaust55 often puts his stuff in Finished Project - Miscellaneous.
I'm surprised that no one has mentioned Manual 2 - Basic Commands. Variables are discussed in the section titled "Variables - General" on page 13.Hi, I am using a 18M2 and am confused over "what" variables I can use... e.g.
'w0 = (also b0,b1)
etc. etc.
