The "General Picaxe Manual" states the following about interrupts:
"Does the PICAXE support interrupts?
The PICAXE uses the internal microcontroller interrupts for some of it’s BASIC
commands (e.g. servo). Therefore the internal interrupts are not available for
general use. However the A, M and X parts all support a single ‘polled’ interrupt
on the input port. Use the ‘setint’ BASIC command to setup the desired interrupt
port setting to enable the polled interrupt. The polled interrupt scans the input
port between every BASIC command (and constantly during pause commands),
and so activates very quickly."
It also states in a tutorial section "Using Interrupts":
"A polled interrupt is a quicker way of reacting to a particular input combination.
It is the only type of interrupt available in the PICAXE system."
However the hintsetup command apparently sets up hardware interrupts on the X2 chips which I would gather interrupt after execution of a hardware level rather than a Picaxe instruction (this being much faster esp on Picaxe blocking instructions(?)).
Is the documentation out of date or is my understanding of it incorrect?
