I think I might have damaged my axe027 cable or installation.
Can I just get someone to confirm that the following test should work, on a normally functioning and installed axe027 cable?
from axepad
options>usbsetup
The following USB Serial Devisces existg on this computer -
/dv/tty.usbserial-0000101D
then again from axepad:
options>High (then measure V across serin-gnd - 3.9 V)
options>Low (then measure V across serin-gnd - 0.1 V)
I gather this suggests that installation is ok.
BUT.
connecting the serin to serout. -i.e putting a jumper across the collar and ring, and then typing "hello" into the "output buffer" in the terminal, does return any response in the input buffer, which I thought should happen.
Can I just get a quick confirmation that I have this part, at least, correct?
thanks to all.
from axepad
options>usbsetup
BUT.
thanks to all.
