And here, two programms tested whith picaxe the first one work the second bot
so the picaxe can detect the "0" information
it can detect that an information is not a zero
but it doesn't recognize the "1" information
If all you are wanting to send from the PC to the Picaxe is a simple 1 or 0 it would be easier to do that with one of the RS232 status lines instead of data over Rx/Tx.
hi
answer to lewisg :This programm is just the begining. After i want to send complex data. that's the reason why i use rx/tx
answer to allycat:you're right i'm testing this program whith an old 28x1. But it doesn't explain why it can't read the binary "00000001" value
For two devices to communicate successfully on SERTXD, you need to ensure that the baud rate, polarity and start and stop bits are the same for both ends of the link.
So if it does not work, you can always check the manuals to see what the default settings are.
