Hello,
I'm working on a 8 segment sequencer with the 20M2. I can currently figure out how to cause a string of 8 outputs to go high and low in succession with only 1 pin being high at all times. I use the wait command between pins then restart the code.
That's pretty archaic. I was wondering if there was a way to define the speed at which the cycle runs using a potentiometer input or a tap tempo input. If you could point me in the right code direction I'd love to read up about it.
It would be great to have to gliss between the outputs, but I'm interested in getting the speed under control first. Thank you for any advice.
I'm thinking that a pot could be connected to the analog in and the voltage read to a variable, which would then be used to set the pause time.
