What voltage are you measuring and with respect to what?
As already mentioned, the output of a darlington with no load will be about half a volt irrespective of it's input being high or low.
So, your relays click but don't switch.
That suggests a coil voltage problem.
Are they 5v relays driven from a 5v supply using the darlington to drive them?
If yes, then it may be that the volt-loss in the darlington (~1v) is too much and your circuit could never work.
If you have the relays direct on a PICAXE I/O pin, then you will most likely destroy (if have not already) the PICAXE.
Please post schematic and/or photo of your setup.
Please provide link to datasheet or give details about the relay.
Here is the CHI030 as I currently have it setup, 12VDC goes into a 5vdc regulator and then into the pucaxe side of the CHI030, 12VDC into the darlington side. Resistor is removed as per data sheet
Here is the pic of the wiring coming out of the darlngton side of the CHI030
This is where those wires lead to
lamp cord is run from the speaker terminals to this
The relay is a Varley SPDT, I had found a web page awhile back but did not save it, so I apologise for not being able to provide a data sheet. It is 12VDC to switch and will switch 120VAC. The picaxe is still functional as I have been able to run the first code and it switches the relays, however the second code does not.
