Regulars will remember I posted re. a HV generating circuit a few weeks back. Ive been experimenting with a few options.
Ive settled on adapting a kit/circuit that is used to flash a xenon tube. Nothing new here, a capacitor is charged via a small transformer and a oscillator circuit. The charge in the cap is dump into the xenon tube when the tube is triggered.
pdf here.
http://kitsrus.com/pdf/k163.pdf
(N.B. that in the above C3 is listed as 33uf 350V. The part supplied is actually a 225 /630V device).
I propose to use the charge in the capacitor to produce the shock effect I need. The cap is 225 /630V device. It gives a meaty jolt, I've tested it several times.
As the circuit is now the tube flashes every half second or so.
What will happen if I let the oscillator/transformer part of the circuit simply keep on charging C3/ 630V cap with no flasher part of the circuit connected? Will this damage the cap? Or does the cap simply reach its rated 630V and then develop a internal r that means it can't take any more charge?
pdf here.
