A quick question with reference to the attached schematic.
The circuit uses a MIC2940A-5.0 fixed 5v LDO voltage regulator. The datasheet recomends an output capacitor of at least 10uF and it must be low ESR. OK, no problem with that I just bought some nice 15uF Sanyo Aluminum solid capacitors, however, whenever I use a 'normal' linear regulator such as LM7805 I always add an electrolytic (and) a 100nF ceramic to catch the faster nasties. Would I be ok to do the same with this reg?
N.B. This question was prompted by Dippy's excellent thesis on decoupling capacitors. See, some of us read it
View attachment 5v LDO with Crowbar.pdf View attachment mic2940.pdf
